Stablitrac/Traction Check Lite
Old Feb 27, 2010 | 5:49 PM
weewun's Avatar
Default Stablitrac/Traction Check Lite
2007 Tahoe LTZ with 30,000 miles.
The Stabilitrac/Traction Control Check Lite came on and stayed on. I stopped and turned the engine off and restarted the engine, the Check Lite stayed on.
Stopped for supper and the Lite was off when I started the Tahoe to come home.
Do I have a problem coming. I will appreciate your input.
Old Mar 1, 2010 | 7:20 AM
08 burb fan's Avatar
I just got the same indicator on my 08 Sub w/ 29K miles.
I turned the car off and the lite reset, but it came on again after a few miles/
Old Mar 1, 2010 | 8:15 AM
ousig2408's Avatar
I had this happen also on our 07 Tahoe. both lights were on and the truck was not driveable. I turned it off for a few minutes then restarted and everything was fine. It does talk about this in the manual - so many sensors have to talk just right for everything to work
Old Mar 2, 2010 | 3:16 PM
Make sure your tire pressures are equal.
Try disconnecting battery for 10-20 minutes to reset computers.
Old Mar 6, 2010 | 5:36 AM
The chk brake lite came on in conjunction with the stabilitrak lite so I checked the master cylinder and found the brake fluid was low.
After filling it, everything is now fine.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
rosleo45
Avalanche
20
Mar 25, 2014 9:23 PM
daneil912
Feb 26, 2013 6:37 AM
kd
Jan 30, 2007 1:50 PM
