Stock Grille Inserts? 07'-13'
Old Oct 16, 2013 | 3:07 PM
BlackDiesel's Avatar
Default Stock Grille Inserts? 07'-13'
Are the grille inserts on a Z71 burban/hoe different than on the usual LS/LT/LTZ models?
Reason for asking is because my dealer agreed to swapping my chrome grille inserts to the flat black base model ones (easier to paint). However the service department called and said they won't swap over.
I'm kinda calling bull***t. But then again I haven't had a chance to look at the other grille inserts.
Thanks guys!
Old Oct 16, 2013 | 3:30 PM
titantn24's Avatar
I'd call BS on that too. I don't see why they wouldn't swap over. I'd go to the dealer and have the service guys show me why they "won't swap over." I just don't trust dealers, especially their "service" departments. Good luck.
Old Oct 16, 2013 | 4:03 PM
Would've in a heartbeat if I didn't have the wife and screaming baby with us.
Right now I'm taking the grille insert out myself to get exact dimensions of the inserts themselves and the tabs.
Old Oct 16, 2013 | 4:42 PM
The easiest way to tell would be to have your parts man look up the part numbers for both vehicles. That will tell you whether or not they are interchangeable. AFAIK they are interchangeable.
Old Oct 16, 2013 | 6:27 PM
That's what has led me to the point I'm at now.
Here's the steps I've taken since I started this thread:
1. Called another dealerships parts department and was told the same thing. However the guy kept referring to my burb as a LTZ, I corrected him 4 times that it was a Z71. So the fact he wasn't really listening didn't give me a lot of reassurance.
2. Called 2 aftermarket grille insert replacement companies to ask if I would have an issue. Both of them reassured me that it would be no issue at all and both called their parts specialist to double check.
3. I took the radiator cover off and loosened the top of the grille so I could get a better look at the tabs inside. Also made measurements of EVERYTHING. Took pictures of the bottom tab bracket to see if it's the same for when I go back up there to get the rims and tires put on.
So I'll see how this goes.
Old Oct 17, 2013 | 6:44 PM
Went back to the dealer made them show me why it won't fit.
Lets just say I left with my new black grille on my burb and they filled it up, and washed it.
Woohoo!
Old Oct 17, 2013 | 8:44 PM
titantn24's Avatar
Hmmm, interesting how things change once you're in their face and not just a voice on the phone. I told you I called bullsh** on that! Good for you on going down there and making them keep their word. Take that stealership!!
Old Oct 17, 2013 | 10:13 PM
Thanks man!
whitesox1933
Aug 14, 2012 10:52 PM
s34n
Jun 5, 2010 12:30 PM
handrade_satx
May 31, 2009 9:49 PM
edmart281
Nov 16, 2008 7:38 PM
CarbRage
Oct 23, 2007 4:34 PM
