Strange bushings
Old Jun 8, 2015 | 11:06 AM
Ashot's Avatar
Default Strange bushings
Dear Truck Owners!
I own Chevy Suburban 2003 2500 VIN 3GNGK26U03G215528.
Now I have a strange problem with replacing lower control arm bushings.
Here a pic of my left arm, I found only such # on it - 1223B II K8BL9L which gave me nothing as this is not GM but part #:
As I understood this is not original lower arm as the original one have to look like this:
Probably I have a lower control arms from Chevy Suburban 1500 or Avalanche 1500 (GM 12475479), like this:
So initially I did not know this and bought 2 kits of bushings: 15034801 & 15034802.
But when I started to change them, I saw that they possibly will not fit to my arms, please see the pics:
I saw that the original bushings have the same length but they seem to be any other form (original - more cylindrical and have blunt ends, new are oval and have protruding ends). I am afraid that after the installation the arm will not lock into place....
So could you be so kind and help me to understand:
1. if I am right and have non-original lower arms (don't understand how it was installed?!)
2. what bushings will be correct for my arm (all bushing I found to 1500 or 2500 bases have the same oval forms as mine!)
Thank you to All and sorry if my questions may be stupid )
Kind regards,
Ashot
Old Jun 8, 2015 | 11:38 PM
Rednucleus's Avatar
LOL certainly not stupid questions if I can't answer them!!
Old Jun 9, 2015 | 6:24 AM
I would suggest using RockAuto to compare what you have..
Old Jun 9, 2015 | 8:46 AM
old dog's Avatar
hello , i would suggest calling a gm dealer with the vin number and see if they have them ,and see if you can talk them out of the part number to cross it over they show quite a few different styles probably because of the plant they were made . i cant see in the picture too well but it looks like you have a two piece bushing ,steel inner sleeve and rubber outer .these have to be press in and the rubber outer expands as it is pressed in .
if it has a steel outer shell then rubber then a steel sleeve for the bolt to go through it does not expand the rubber but still presses in.
don m
May 19, 2010 11:37 PM
onesmartidiot@wideopenwest.com
Apr 12, 2010 11:38 PM
waitery
Jun 30, 2009 4:29 PM
2007BURB
Jun 13, 2009 12:52 AM
griff450
Jan 3, 2009 11:24 PM
