Stuck brake pedal
Old May 16, 2023 | 5:17 AM
jemartines8's Avatar
Default Stuck brake pedal
Hello everyone. I need some major help. I own a 06 Tahoe 5.3 2wd. I just changed my brake booster along with the brake cylinder added brake fluid and bled the brakes 3 times. My brake pedal is still stuck in the floor. I don’t know what else to do. Has anyone else had this similar problem? How did u resolve it?
Thank You.
Old May 16, 2023 | 2:39 PM
Welcome to the forum. Did you bleed the new master cylinder? If so, then you might have a bad master cylinder.
Old May 25, 2023 | 12:08 PM
Default Brake pedal
I replaced the master cylinder too. I bled the brakes again. My driver front brake line bleeds really slow let’s some air out and then almost stops dripping as if it has no more pressure.
I had a mechanic bleed the abs module. However my brake pedal is still stuck in the floor and won’t come to place on its own.
any suggestions? Ty.
Old May 25, 2023 | 9:05 PM
oilcanhenry's Avatar
You have air someplace in the system. I'd back bleed it myself. Might be able to rent one at an auto parts store. Make sure to take the M/C cap off or loose, if you do so. And once you do so, get the brake fluid off your paint.
Old May 26, 2023 | 12:35 AM
Default Stuck pedat
What about loosing pressure in the brake line? Does that indicate air too?
ty.
Macneill
Jul 15, 2020 3:49 PM
joe0072
Sep 23, 2017 10:41 AM
MDBowtie
Sep 4, 2016 12:17 PM
David Ruggles
May 15, 2013 9:32 PM
BSmith
Cobalt
Mar 30, 2007 12:35 AM
