Suburban won’t start after rain
Old Sep 30, 2023 | 3:44 PM
berg3606's Avatar
Default Suburban won’t start after rain
I have a 2016 suburban ltz. After it rains or is very humid, it won’t start or the instrument panel doesn’t work. I’ve look for a distributor cap but not sure if it has one.
Old Sep 30, 2023 | 4:56 PM
you don't.
But it does sound like an electrical issue. Do you get any warning lights?
Old Sep 30, 2023 | 7:34 PM
berg3606's Avatar
you don't.
the instrument panel doesn’t work and every warning comes on. Once it dries out. It works.
Old Sep 30, 2023 | 9:43 PM
I would still attempt a diagnostic scan. At least it might give you a starting point. Otherwise you're looking for a needle in a haystack. The fuse box might be a good place to start. Disassemble it and look for corrosion.
Old Mar 7, 2024 | 3:59 PM
jdhop's Avatar
Default rain fix?
Did you ever find out what was wrong? Mine is now doing the same thing.
Everything is normal until you hit the brake and push the start button, then the dash goes black. I can hear a small click on button push however does not sound like starter, will not crank just click and then black.
Old Mar 26, 2024 | 8:31 PM
Chevy1973's Avatar
any luck with yours
Old Mar 26, 2024 | 8:42 PM
Chevy1973's Avatar
Default 16 Tahoe won’t start in the rain
Anyone have any tips also no locks and gauges remote start does work after dries out it’s good
Old Apr 3, 2024 | 1:25 PM
JMStein's Avatar
Default Any Ideas?
Pretty wet air on the east coast right now and my 2018 Burb is dormant due to this issue. This same time last year it did this and we replaced the battery thinking it was bad.
Personally when she dries out I am going to go through the electrical connections with dielectric grease. But, as it is she is inoperable.
It happened on March 6th this year and again on April 1st only this time she started once yesterday by remote but would not start again.
Any ideas would be helpful
Old Apr 11, 2024 | 11:37 PM
burbanonrims's Avatar
has anyone tried replacing the body control module I’m having the same issue an that’s all I can really come up with for fixing some of these issues I put a new battery in. An it has a drain. Then all the warning pop up. When started the buttons on the remote sometimes work for unlocking the doors or to open back hatch lights flicker inside
Old Apr 12, 2024 | 12:17 AM
Originally Posted by burbanonrims
An it has a drain.
find the drain
