Suburban won't start!
Old Sep 23, 2017 | 4:32 AM
  #11
Azuber01's Avatar
Thanks! I got it to start after a while by turning it over and feathering the gas. Definitely sounds like it's only running on 6. I'll have to check the injectors this week sometime.
Old Sep 25, 2017 | 5:50 PM
  #12
Matt B's Avatar
Either a PCM issue or hardware.. Good Call Shark
Running on 6 should help your fuel economy. >.<
Old Sep 29, 2017 | 12:01 PM
  #13
Azuber01's Avatar
changed the injectors. only running on 3 cyl now! even better mpgs. so I changed the injectors again and now it won't start at all again. I don't get it. I don't think it's really a injector issue
Old Sep 29, 2017 | 6:17 PM
  #14
Matt B's Avatar
Test the compression? Might be valve or piston related.. could even be timing
Old Sep 30, 2017 | 4:14 PM
  #15
Azuber01's Avatar
haven't tested compression. but it didn't have a issue before. I'm almost afraid to check
Old Sep 30, 2017 | 4:39 PM
  #16
Azuber01's Avatar
compression is 150ish on all 8
Old Oct 2, 2017 | 10:19 AM
  #17
Matt B's Avatar
We're chasing our tails here. Sorry I haven't been more help.
Fuel-- Filter: check. Pump: check. Pressure Regulator? Pull the vacuum line and check for gas. diaphragm could be toast..
O2 sensor? Could be doing a terrible job without throwing a code. $100.00 to replace all 4 - if you can get 'em out they can be 'cleaned' by soak in gas overnight.
MAF senor- Pop it out and hit it with some carb & choke or special MAF cleaner..
My boss just asked me if I want to buy her 03 burb.. 194,000mi $2500.. Thinking about selling the Subaru so I can go through all this with ya. Any takers?
Old Oct 2, 2017 | 11:16 AM
  #18
Azuber01's Avatar
that's a excellent idea! I wouldn't hesitate for a second on that's deal. I was thinking maybe the crank sensor is bad and it's not firing right? I'm sick of throwing money at this thing!
