SUCCESSFUL MIRROR SWAP (EXCEPT)
Old Feb 24, 2008 | 5:04 PM
Aquarius14's Avatar
Default SUCCESSFUL MIRROR SWAP (EXCEPT)
After swapping mirrors & having them programmed I still don't have auto tilt when in reverse (which I didn't really expect) but also the puddle lights don't work.[] Is this normal or should the puddle lights at least work when approaching car?
Old Feb 24, 2008 | 5:24 PM
tahoe07's Avatar
Default RE: SUCCESSFUL MIRROR SWAP (EXCEPT)
When you get out it will not light up. When you unlock with remote, puddles should light up.
Old Feb 24, 2008 | 5:45 PM
Not sure but you may have to have the dealer program them (or is that what you meant by having them programmed?) to get the Auto tilt to work in reverse since this is programmed from the DIC.
Old Feb 24, 2008 | 5:48 PM
Aquarius14's Avatar
I get nothing when I unlock the doors.
Old Feb 24, 2008 | 9:50 PM
xclusive's Avatar
ORIGINAL: Aquarius14
Did you make sure you plugged all the harnesses back in to the driver door module and passenger door module? If you did all that then you might have to go to the deal and have the modules reprogrammed...Just tell them that the doorlocks stopped working and dont say anything about you upgrading the mirrors cause the might give a hard time.
Old Feb 25, 2008 | 7:10 PM
bobbyt's Avatar
wait one sec are you guy's saying 07 tahoes side mirrors auto tilt in reverse ? BECAUSE MINE SURE DONT IN MY LT3 AND WANTED THIS OPTION.
Old Feb 25, 2008 | 7:16 PM
deejayrock's Avatar
Hey Bobby,
Yes they do, i also have a LT3, are you sure you dont have this option? you may want to check with your dash computer options, you may have to activate it. You can make them both tilt, just one of them tilt, or dont tilt at all.
check it out, it may be hiding from you.
-deejayrock
Old Feb 25, 2008 | 7:46 PM
bobbyt's Avatar
thanks dee i will check it for sure.
Old Feb 25, 2008 | 9:55 PM
The owner's manual is your friend.
intheburbs
May 18, 2015 10:23 AM
QUETRANPA
Jul 17, 2012 5:36 PM
pookster71
Dec 27, 2007 11:36 AM
tahoe2007
Jan 9, 2007 11:26 AM
