Suggestions for abandoning the Bose system speakers and amp
Old May 6, 2019 | 11:30 AM
Disasterman's Avatar
Default Suggestions for abandoning the Bose system speakers and amp
I just bought a used 2007 Tahoe LT, (My third Tahoe) which had a base model factory Bose radio/CD player, (no Nav or touch screen), and just installed a Pioneer MVH1400NEX head unit, connected to the factory Bose system amplifier and speakers with an iData Maestro converter and wiring harness to work with the factory steering wheel controls. The head unit was highly rated (for my price range) and I had a Pioneer in a prior Jeep I owned. It sounds pretty good, but the speakers in a couple of the doors are blown or distort really bad. Some say this is a water issue.
From my understanding of other threads, the 2007 Tahoes Bose amplifier is under the center console, along with some subwoofers, and it was designed for the specific Bose factory speakers that came with the truck, including the front door speakers that are under 2 ohm, with a crossover connection to the A- pillar tweeters, and the rear doors which are 4 ohm, and a couple subwoofers under the console. There are no other speakers. The iData adapter supposedly adapts the Bose system to the Pioneer head unit.
After looking at the forums, and reading that not only can the door speakers suddenly fail, but also the amp itself can go bye-bye, I'm not thinking that I want to spend $40 to $50 per speaker to replace the door speakers with the same dismal OEM Bose factory speakers for $40 to $50 each. The old adage about doing the same thing over and over and expecting different results seems to apply....
Everyone says I could get some much better speakers that would work directly with the new head unit. I'm on a limited budget, and don't have a huge amount of money to spend, so I don't want to get into a money pit replacing all that factory stuff.
SO, what I'm wanting to explore, is replacing all four speakers, retaining only the plastic mounts (which mount the speakers about an inch or so out from the metal door frame), and mounting replacement after market speakers to them, like in this video:
and using some weather shields behind them, and maybe a foam ring in front of them. Then, in the front A-pillars, installing some
aftermarket tweeters, and finally, a new subwoofer under the center console where the existing Bose subs are.
I was told that the Pioneer will power such a speaker arrangement without needing an auxillary amplifier, or that I could get a relatively cheap amplifier and that there are subs that would fit under that center console in place of the Bose system.
Can you recommend what I should use in the way of new speakers that will work well with the Pioneer head unit?
Any ideas on how to integrate all that with the iData Maestro and wiring harness since there wouldn't be anymore Bose system?
Do I leave the iData Maestro and harness intact for the factory steering wheel controls?
Any help appreciated, and when the aliens land, I will tell them to give special treatment to any of you that help me.
Old Jun 4, 2019 | 12:47 PM
Hayden Hamlin's Avatar
I completely did the stereo system in my 05 burban with some polk audio 6 1/2" front and back. Pretty sure i only paid 120 for 4 on amazon and there by far the best speakers ive ever had. As far as the sub im not sure i out 2 12 inch kickers i found on amazon for 400 with the amp and wiring kit.
Old Jun 6, 2019 | 11:14 PM
Thanks Hayden!
Old Jun 6, 2019 | 11:48 PM
No problem. I do very much recommended even if you dont change the speakers is to do the big 3 setup under the hood. You'll notice a huge difference in ur whole electrical system
