Synthetic Oil vs Standard Oil
Old May 8, 2009 | 3:18 PM
JCRAMOS's Avatar
Default Synthetic Oil vs Standard Oil
I have 98,000 miles on my 03 Tahoe, should I use Synthetic or Standard Oil, Is it Really... worth the double the price or more???
My regular oil change intervals are at 3,500 miles and have only being using standard oil with out a problem BUT should I being using Synthetic??
Old May 8, 2009 | 3:32 PM
Mike Sigmond's Avatar
ROTM Coordinator
I dont want to get another debate on oil going again.
Check this thread out, it might explain it for you.
https://chevroletforum.com/forum/sho...hetic+Standard
Old May 27, 2009 | 5:15 PM
yarom's Avatar
Default Don't move to synthetic this late
You might develop leaks if you have that many miles.
The right time to convert to synthetic is around 6K miles and/or after full break-in.
Old May 27, 2009 | 7:39 PM
MDTAHOE's Avatar
Professional Mechanic
Changing to synthetic WILL NOT cause leaks. If you already have a slight oil leak and you switch to synthetic it MAY leak worse because the molecules are smaller and more slippery. As long as you change your oil regularly then you are fine. At that mileage any wear on the engine is already happened if you start with a newer engine the wear will happen at a much slower rate.
Old May 28, 2009 | 6:18 AM
Hardin Thicke's Avatar
For me 3,500 miles between drains doesn't warrant synthetic oil. I use synthetic oil in the mine initially because I was driving 100 miles a day to work and back. Now I use it because it sits in the driveway most of the time, and I'll be going perhaps a year between drains. Personally. I'd stay with what you're using unless your drain intervals are many months apart.
Old May 28, 2009 | 11:40 AM
The synthetic may cost 2x more but you will not need to change it as often...
pay more to do less or pay less to do more... its how it works
and 3k oil changes are BS even with regular oil... the wifes minivan is a 4 cyl. with nearly 90k miles on it and I have her get the oil changed at 4-5k miles with standard oil and its still running strong...
I used mobile-1 in my 97 Tahoe and at times would go 12K on an oil change and it was still running great at 147k.
My current 07 Tahoe is at 23k miles and is coming up on its 3rd oil change and that is based on the Oil Life Monitoring System's recommendation with standard oil , thou I do use Mobil1 in it also.
It comes down to:
how long do you plan to own it
How well do you maintain it
How do you drive it
What kind of conditions do you drive in
art
Sep 30, 2020 7:53 AM
Danistheman1234
25
Aug 9, 2011 5:16 PM
Danistheman1234
May 26, 2011 6:59 PM
Rod Man
Nov 6, 2010 9:21 PM
mike3401
Camaro
14
Sep 22, 2009 11:47 AM
