Tahoe 2001 ls after market stereo help.
Old May 27, 2020 | 11:04 PM
th3-0n3's Avatar
Unhappy Tahoe 2001 ls after market stereo help.
Hello I need help with my car stereo. Before replacing my factory stereo I was able to change the level of the sub but after I replace my factory stereo on my Tahoe 2001 ls I'm unable to adjust the level. First I was having problems where the sound wouldn't come on. I learned that I needed to power the factory amp I think it was so I connected the pink wire to another cable. Now I get sound on all 4 channels, they work and the factory sub on the back also turns on but the problem is that I cant control the level on the sub. I can't make it have more bass or have less.
If I go to my stereo and check the equalizer I can make the sound come out of a single speaker on any of the four side or what ever I configure, also I'm able to edit each band on the equalizer and it changes the sound. but the sub no matter what I change it doesn't change. There is a band for the sub on the equlizer but if i move it all the way to the bottom or all the way to the top the sub still sounds the same.
how can I fix this ?
is there a cable I miss the lets me control level.
any tips would be greatly appreciated to help me fixed it. Since ill be replacing my stock sub since I think its blown so I can fixed it the same day.
Old May 28, 2020 | 4:14 PM
TrentC's Avatar
For a new one, you can visit Crutchfield to show you what can fit in there. Looks like Double DIN
Old May 28, 2020 | 5:53 PM
th3-0n3's Avatar
Default Can't change sub-woofer level on after market radio tahoe 2001 any help?
Yes it is a double din. I made it fit and all but just the sub level i'm unable to change. Yes I check the site out to see what I needed.
all speaker channel work and I can edit the equalizer and change how they sound.
Claire Dyar
Mar 11, 2018 3:17 PM
Jody Bunner
Dec 23, 2017 12:49 PM
edyjbargel
Oct 11, 2017 7:36 PM
Tomwa
Mar 22, 2010 2:15 AM
uraijit
Jul 25, 2007 12:05 AM
