Tahoe brake issue
Old Dec 13, 2012 | 11:39 PM
tonyvisone's Avatar
Default Tahoe brake issue
hey all,
i need some serious advice for this truck..... 1998 tahoe 5.7L 165K miles
apparently somebody put power steering fluid or something petrolium based in the master cyl a while back. i recently cleaned the whole system out will brake cleaner, and then installed new calipers, wheel cyls, master cyl, 1 of the 3 rubber lines (because the other two didnt want to come out), and the abs module (with a known good one off a buddys tahoe that he scrapped due to an accident).
so i bled the brakes a TON.... far over a gallon through it. no more bubbles, but the abs and brake lights were on. i bled it more but nothing changed
now i have been driving it, and the red brake light is off, and has been staying off.... the abs light is still on..... i dont think the abs is working.... i can lock the brakes up... the brake pedal is spongy, not like super spongy, as i can lock the brakes up, but its a little spongy up top and i can push it to the floor easier than i should be able to.... mind you i can lock the brakes up... ive driven over 1K miles like this without any issues
any help/advice is much appreciated!
Old Dec 14, 2012 | 11:46 AM
SWHouston's Avatar
Keep trying...
Just in case you missed something, you might check out...
http://www.brakeandfrontend.com/issu...ontentid=38615
Old Dec 16, 2012 | 10:32 PM
inthechateau's Avatar
To properly bleed the ABS module you need to open the spool valves with tool J-35856(you need three of them) and have a scan tool to cycle the spool valves open to get all air out of it. Problem is usually only dealers have the scan tool that works on these ABS modules. I've been driving my 96 tahoe with the ABS light on for 2 years cause I can't make myself pay a dealer $300 bucks to bleed my brakes, just goes against teh grain. So light will stay on until I come up with a better solution. Good luck
Old Dec 18, 2012 | 10:30 PM
tonyvisone's Avatar
houston- keep trying what? normal bleeding? after it had no air at all i mustve put another 3/4 gallon through. thanks for the links. second one looks like itll be helpful, but i havent read it yet. i imagine i will need to do what chateau wrote about------------ chateau, i have heard of this before (the abs bleeding scan tool thing), but i dont want to pay the dealer either--- but i cant pass inspection with that light on- how do you pass?? and also, i heard that i can bleed the abs manually by locking up the brakes a bunch and then bleeding at the wheels again..... any info on that?
thanks all
Old Dec 19, 2012 | 11:57 AM
SWHouston's Avatar
Yes, I was implying to keep trying to bleed them, but, I had forgotten how much you'd put though it already. Is there some sort of sensor, could that be bad ?
Old Dec 20, 2012 | 9:45 AM
tonyvisone's Avatar
its possible, but i just replaced the entire ABD module unit. i plugged all the plugs in.... can the abs light come on for air inside the module? but not the red brake light?
cmcbride
Avalanche
Aug 8, 2012 3:12 PM
Thad W. Posey
Jun 15, 2012 9:21 AM
Jason529
Aug 2, 2011 12:36 AM
tom5170
Mar 19, 2010 11:57 PM
