Tahoe LTZ 2007 Tailgate open and close ath the same time. User from Germany need help
Old Mar 30, 2018 | 9:09 AM
poertsch's Avatar
Default Tahoe LTZ 2007 Tailgate open and close ath the same time. User from Germany need help
Hallo to all users here at this Forum of Chevrolet cars.
First of all my name is Markus and I am from Germany near Wuerzburg. I am now for 3 weeks an owner of an 2007 LTZ 5.3 Tahoe. Its an nice car and not many people drive such model in Germany.
So now i have one problem that i cant solve with my experience in electrical issues.
Here is the problem:
I was parking my car in front of my house. I was opening the tailgate without problem with my remote control. Close it with the push button at the tailgate. I was parking the tahoe inside of my garage and would open again the tailgate. So i was was seen that the tailgate was open about 8-10" and close again by it self. I was searching internet and read that the lifters on the left and right side would went out. So i order Strongarm 6156 lifters. I was replace them with the hope that i solve this problem. But i was thinking wrong. The problem is still the same.
I can touch my sensor inside of the handle. Then i hear the sound for unlocking the tailgate. Motor start pushing up to 10" and close again by it self. I test it with my remote control the same issue. Also i test it with the roof switch for the tailgate. Same problem.
I was unlock the tailgate with the roof button and open my tailgate manually. It works normal. Pushing sensor tailgate would unlock and I can open it manually. Bute i hear the unlocking sound for some seconds when the tailgate is main open. Is this normal in manually mode?
So then I test it again. Push the roof button back to electrical mode. Pushed the open button on my remote control and then in the open mode i was helping the tailgate manually to lift and the motor was pushing up the tailgate. At the open position i was pushing the close button at the tailgate. The close move was beginning I hear the typical sound of the tailgate but motor only push up a little the tailgate and wont close it. Stays open.
So i have no idea what could be this problem. I was thinking that maybe the motor went out. Because why it stop working after i was use it outside in front of my house. Lifters are brand new. Or did i order wrong lifters they are not strong enough. But why it would not close then.
I have no experience in this point. Also no electrical wiring diagram. Here i need help as much as possible. I start to get me al necessary books and tools to work on my Tahoe by my self. I have no TECH II Tool. I have only Auto Delphi 2015 to check the OBD2 box. But it seems that i need an special software to read all data out of my Tahoe.
I hope that one of your guys here could help me in my problem. In other Forum no body answering me at my post.
Thanks a lot for all help and info's. If you like you can send me an PM and i will give you also my E-mail address for contact.
Thanks a lot your Member Markus
Old Mar 31, 2018 | 8:04 PM
sfcjones's Avatar
It almost seems that the tailgate is sensing something that makes it going into a safe mode. If you tried to open the tailgate while gently applying upward pressure I am curious to see how the tailgate reacts. Or if it is trying to close what would happen if you prevented it form closing all the way., Would it open all the way by default? Curious if this would happen.
Old Apr 1, 2018 | 6:55 AM
poertsch's Avatar
Hallo sfcjones. First i wish you an nice eastern Sunday to you and your family.
At the moment I am 600mls away rom home at my girlfriends house. I drive home today. What i will do is, that i make an Video about my problem.
There i can show you how my Tailgate would react. I think this ist the best way to show everybody what is my problem
Also i was reading that my problem could be because my release switch of my tailgate is stocking in. Because i fell no mechanic response
if I try to push this button. It feels like an sensor pad. I know on my german car that if I would push such button, that you getting .an feedback
in your fingers if you push this. But at my handle nothing would feel like this. Also i have to press it sometimes very hard and often because this switch will
not react by my fingers.
Maybe i will try to replace first this Tailgate release switch and go step by step to solve the problem. Because in manually Mode i can use my tailgate.
What you think about my Idea. ???
Best Regards Markus .
Old Apr 2, 2018 | 4:49 PM
poertsch's Avatar
Default Find some interesting Information for all Owners of an Tahoe up 2007 -
Subject:Power Liftgate May Open or Close About a Third of the Way Then Reverses, DTCs B153B, B153E and/or B153F Set (Inspect Liftgate Wiring Harness and Repair as Necessary)Models:2007-2009 Cadillac Escalade, Escalade ESV2007-2009 Chevrolet Suburban, Tahoe2007-2009 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL with Power Lift Gate (RPO E61) This bulletin is being revised to change the diagnostic code information. Please discard Corporate Bulletin Number 07-08-47-005A (Section 08 -- Body and Accessories).
Condition
Some customers may comment that the power liftgate opens about a third of the way and then reverses to the closed position. Other customers may comment that when the power liftgate is open, the liftgate starts to close about a third of the way and then reopens. The technician may find diagnostic trouble codes (DTCs) B153B-Liftgate Open Switch Signal Circuit, B153E-Liftgate Position Sensor Signal Circuit and/or B153F-Liftgate Object Sensor Signal Circuit set.
Cause
The cause may be a sharp sheet metal edge inside the inner roof panel chafing the liftgate wiring harness.
Old Apr 2, 2018 | 4:59 PM
poertsch's Avatar
Correction
Inspect the liftgate wiring harness and repair as necessary using the steps below.
  1. Verify the condition and check for any DTCs.
  2. Remove the rear door upper garnish molding and retainers. Refer to Rear Door Upper Garnish Molding Replacement in SI.
  3. Remove the headliner push retainers.
  4. Important: Do not fold or crease the headliner panel.
  5. Slightly pull down on the center of the headliner panel.
  6. Locate connector C405/X405, which is a light gray 22-way connector located under the center of the rear headliner panel.
  7. Tip
    Use a shop towel when disconnecting the rear washer hose to help absorb any washer fluid that may leak.
  8. Disconnect the C405/X405 connector and the rear wiper washer hose.
  9. Remove the wiring harness pass through retainer, wiring harness, C405/X405 connector and the washer hose from the roof panel.
Old Apr 2, 2018 | 5:06 PM
poertsch's Avatar
10.Visually inspect the liftgate wiring harness as shown above and repair any damaged wires. Refer to Wiring Repairs in SI.
11. Important: After repairing the wires, wrap the wiring harness with electrical tape and install conduit.
12. Install a piece of Kent-P92565, wire harness wrap 18 mm (¾ in) inside diameter (I.D.) by 145 mm (5¾ in) length or equivalent flexible conduit to the liftgate wiring harness.
13. Install two pieces of Kent-KT13080, Posi-Seal PlusTM or equivalent of electrical moisture sealant pad to the lower inner flange (1) inside the roof panel.
14. Install the liftgate connector C405/X405, wiring harness and the rear washer wiper hose back through the roof panel.
15. Connect the C405/X405 connector, the rear wiper washer hose and seat the wiring harness pass through retainer.
16. Clear any DTCs.
17. Open and close the power rear liftgate ten complete cycles.
18. Install the headliner push retainers.
19. Install the rear door upper garnish molding.
20. Verify that the condition has been fixed.
Parts Information
Order Kent*-KT13080, Posi-Seal PlusTM and P92565, Wire Harness Wrap from Kent Automotive at 1-888-YES-KENT
Old Jan 30, 2022 | 7:16 PM
AAaa1122's Avatar
HI
i have a GMC 2010 with the same problem and i wish you're cars problem is already solved if you can please help out of this
Old Jan 31, 2022 | 12:00 AM
poertsch's Avatar
Hello, I am happy to provide information here. In my case and further research has shown that this error can be found in the Motor of the electric tailgate behind the Tailgate Handle. Liftgate Latch
​​​More precisely, there are micro switches on the motor to check the position on and. If one of these does not work properly, then the measurement in the electronics does not know where its position is and shows this behavior. I wrote in an other Forum an description also for people in Europe because this latch would be also found in the German Opel Insignia Station Wagen. It is the same part and was 100$ cheaper even on Rock Auto..
I hope I could help you.
Greetings Markus
