Tbi engine problem
Old Jan 15, 2012 | 7:21 PM
Unknown1329's Avatar
Exclamation Tbi engine problem
Hi I have a 1995 Chevy Sub with 205k on the engine. I have had a surging idle problem and it seems to be a disappearing problem. It will happen once in a while then run good for a while. I really need help on this one I have no idea what is wrong. I have replaced some things. All of this was replaced after the problem started.
Coil pickup on distributor
Spark plugs
Spark plug wires
Cap
Rotor
Throttle position sensor
Idle air controller
The last two were replaced twice. Once with used parts off a spare engine then again new. After initial replacement each being 3 weeks apart it worked fine then started acting up again.
The rpms at idle or in gear at any speed will drop suddenly low it tries to stall then they surge back up. When this happens I obviously loose power and have gotten myself close to an accident a time or two. I was supposed to take this on a trip recently and wasn't able. The way it is it's costing me a lot of money. I need help please ASAP. Thanks a lot for any help
Old Jan 16, 2012 | 7:50 AM
shamrock246's Avatar
did you check the fuel pressure and map sensor?check the connection and voltage at the coolant temp sensor and the resistance hot and cold
Old Jan 17, 2012 | 7:24 AM
jplinville's Avatar
With that many miles, the first thing I would have done is a Sea Foam treatment...maybe two of them!
Old Feb 21, 2012 | 10:18 AM
livin2k20's Avatar
my 95 hoe was surging it ended up being the egr valve caked up with carbon replaced that now she runs fine with 325,000
nothinBUTaGMthang
Apr 1, 2021 4:27 PM
John808
Oct 29, 2014 8:22 PM
wagn6137
11
Oct 4, 2011 6:49 AM
Vandura
Apr 4, 2011 1:22 PM
talltodd1
Oct 9, 2006 12:37 PM
