Temp for outside air temp
Old May 11, 2010 | 4:18 PM
montana suburban's Avatar
Cool Temp for outside air temp
99 GMC Yukon. The reading for the outside temp stays at 0 C and will not read in F at all, the compass works and gives direction acuratly, Wonder if the sensor for the temp is defective or if there might be some other problem. Does any one know where the sensor is located and if the could be the problem, or is it a fuse issue
thanks
Old May 11, 2010 | 4:38 PM
I can't say for sure on the 99 but I would venture that the temp sensor is located in the front grill area. You might try disconnecting the battery to see if it resets...
Old May 11, 2010 | 5:19 PM
thanks will look there and will try the battery disconect to see. I was just in austin two weeks ago hope the weather is better now than then.
Chris777
Cobalt
Oct 27, 2015 4:13 PM
Adtranz
Jul 3, 2015 9:15 AM
skategranger
Feb 18, 2013 2:38 PM
drakefamily2
Apr 29, 2008 4:36 PM
slick8up99
Jan 28, 2007 1:10 PM
