testing Ignition module
I have a 99 suburban with 5.7 L 4wd.
I'm trying to test the ignition module using the Actron sensor tester Pro. The manual shows the 4 pin GM module as the module in the distributor with 2 connectors on each side. I have the external control module that is a 4 pin with a single connector with 4 pins in a row. see image below. I don't know how to connect this tester to the module to check. I haven't been able to find a pin out diagram for this module. If you can help I'd appreciate it.
thanks,
Frank
[IMG]local://upfiles/15129/1D18EABC632D4B3C828E9E99E0A9F89E.jpg[/IMG]
thanks,
Frank
94burb
Aug 2, 2009 8:06 PM
mikeski
Feb 16, 2006 9:41 PM
