testing Ignition module
Old Jan 26, 2008 | 12:48 PM
fjdavid's Avatar
Default testing Ignition module
I have a 99 suburban with 5.7 L 4wd.
I'm trying to test the ignition module using the Actron sensor tester Pro. The manual shows the 4 pin GM module as the module in the distributor with 2 connectors on each side. I have the external control module that is a 4 pin with a single connector with 4 pins in a row. see image below. I don't know how to connect this tester to the module to check. I haven't been able to find a pin out diagram for this module. If you can help I'd appreciate it.
thanks,
Frank
[IMG]local://upfiles/15129/1D18EABC632D4B3C828E9E99E0A9F89E.jpg[/IMG]
Old Jan 26, 2008 | 2:41 PM
RonH's Avatar
Default RE: testing Ignition module
Autozone, and I thinkO'reilly's or Advance Auto have testers and they will check it for free.
pjm333
Aug 19, 2015 3:40 PM
94burb
Mar 15, 2009 11:40 AM
mikeski
Feb 16, 2006 9:41 PM
