Tire Pressure Monitors???
Old Nov 26, 2007 | 5:19 AM
ncfr2544's Avatar
Default Tire Pressure Monitors???
Not sure if this has been posted before...does anyone know if the TPM sensors can be changed from factory wheels to a new set of 20's? Or do I need to purchase a new set from GM?
Old Nov 26, 2007 | 7:39 AM
e's Avatar
e
Default RE: Tire Pressure Monitors???
it can be done, or you could get new ones. either way...........check around with your local tire shops and make sure you feel comfortable with their response to the removal of the sensors. Around here their quick to say it cant be done. If all else fails check with the dealer. They swapped a factory set into some 24's for us the other day, and even had the machine to balance them.
Old Nov 26, 2007 | 12:36 PM
I do recall a post sometime back that stated that there were some wheels that the sensors won't fit.
Old Nov 26, 2007 | 12:50 PM
ncfr2544's Avatar
I have purchased a set of '07GMC Yukon OEM 20's...so in that case it sounds like they will probably fit....thanks for the replies.
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
Classical Glass
Aug 13, 2007 12:08 PM
xclusive
Jul 31, 2007 8:47 AM
xclusive
Feb 8, 2007 6:29 PM
