Old Jul 29, 2015, 1:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Wheels and Tires
Print Wikipost
tire size ?
Old Apr 22, 2013 | 8:17 AM
rfbznb's Avatar
Default tire size ?
hi
I have a 04 burb and I was going to put 285/75r16 on it and I was wondering if I had to reprogram the computer for the tires or is it ok just to run the bigger tires
Old Apr 22, 2013 | 8:41 AM
SWHouston's Avatar
I don't know if you can re-program the Computer to the larger diameter on a 04. But it certainly would be helpful to you it you could. If you can't, you can calculate the speedometer error and just remember/deal with that, and the perceived changes in Breaking and Power.
That's a pretty hefty change in Tire size (I think), I'd be more worried about them scrubbing. What is the original size recommended for your 04 ? Look on the sticker on the drivers door for that.
Are you changing Rims as well ?
Old Apr 22, 2013 | 9:58 AM
rfbznb's Avatar
stock size is 265/70/16
im using the stock rims
Old Apr 22, 2013 | 11:41 AM
M800's Avatar
If you did want to change the computer for bigger tires you could buy a hyper tech chip and on that you can change the computer for bigger tires and the hyper tech chip might also give you a little more horsepower and fuel economy
Old Apr 22, 2013 | 12:18 PM
rfbznb's Avatar
thank you
Im going to look into the hyper tech chip
Old Apr 22, 2013 | 3:20 PM
SWHouston's Avatar
The 285's are .6" wider, and 2.2" taller than your OEM.
I don't think that's going to be too much for your existing Rims.
However, that's a respectable increase in Diameter.
Hope you can re-program, or get a Chip that'll accept that size.
You will probably notice a little more difficulty in Breaking and
the perceived Power of your ride.
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
slammerslugs
11
Aug 12, 2008 1:48 AM
313hitman
Feb 4, 2008 5:01 PM
WOODDOGG
Jan 29, 2007 11:17 PM
technoswede
Jan 3, 2007 9:15 PM
