Tires??
Old Aug 17, 2008 | 5:35 PM
jlenkows's Avatar
Default Tires??
Been gone a while, but... well, here I am again....
My factory tires (07 Hoe LT3) are a bit on the lousy side. In the snow, they don't have very good traction. In the rain, they don't have very good traction.
I'm looking for some new tires.... with REALLY good traction, that don't reduce my MPG, and thatdon't make any additional noise.
Any ideas????
Old Aug 17, 2008 | 6:44 PM
Default RE: Tires??
My understanding is that:
Harder Rubber = better MPG, longer tire life, less traction
Softer Rubber = less MPG, shorter tire life, better traction
Noise = aggressive tread
probably not a lot of help but....
I like the looks of these but some others in the forum said they didnt have good luck with them
http://www.toyo.com/docs/tires/tires...=lgt-suv-truck
Old Aug 17, 2008 | 9:37 PM
Default RE: Tires??
Awhile back ZX recommended Goodyear Wrangler Silent Armor and the OEM Bridgestone Dueler. He said they were better than Michelin LTX/AT and BFG All-Terrain T/A KO.
Old Aug 18, 2008 | 12:53 PM
guvner's Avatar
Default RE: Tires??
Anyone else with opinions on the tires? Need to replace my factory Hoe 2007 tires too... Guvner..
Old Aug 19, 2008 | 12:37 PM
knotacare's Avatar
Default RE: Tires??
I find the best thing to do is get on tireracks site & compare tires. The most expensive is not the best by a long shot & the same tire has different qualities in each size. So pick your size then find a tire that matches what you're looking for. Such as treadware, noisy or quite, traction in water & snow, etc.
Alan
Old Aug 19, 2008 | 7:12 PM
Default RE: Tires??
jlenkows, how many miles did you get out of the factory tires and which ones did you have?
Old Aug 19, 2008 | 7:47 PM
jlenkows's Avatar
Default RE: Tires??
I have 17,975 (dropped it off at the dealer today)..... The tires basically have barely a full snowy winter left on them. Kind of sad too a $43k vehicle that is ready for tires after less than 20K miles. It's not like I don't have them rotated and aligned every 3500 miles (lifetime alignment and rotation at Firestone shop).
I'm also questioning the brakes - which is why it's at the dealer today. There's a bit of a vibration when they are applied. Also, the pedal isn't as 'firm' as it used to be and stopping distances are longer.
Old Aug 28, 2008 | 5:25 PM
Jritchey's Avatar
Default RE: Tires??
wow 18K on tires. You should ask dealer to call the tire co and see if you can get some help on a new set. I have factory 20's and my tires have 65K on them and just now need replaced. Also, have the dealer check your rotors I warped 2 sets of fronts that the deal replaced at $0. Hope this helps.
Old Aug 28, 2008 | 6:45 PM
old dog's Avatar
Default RE: Tires??
i just bought cooper atr's they seemed to be the best of both world's that i could find .great traction ,pretty quiet .
JHarris8732
Nov 10, 2011 11:25 AM
scootr68
Jul 23, 2010 6:06 PM
bocajeff
10
Mar 31, 2010 12:41 PM
Andy
Jan 29, 2007 11:57 PM
