Tow/Remote Battery
Old Jul 5, 2008 | 6:05 PM
mary900's Avatar
Default Tow/Remote Battery
I havea trailer with a full size battery that is to be used with a winch. Is the "battery feed" wire on the Tahoe's 7-pin connector adequate enough and fused properly to charge the trailer'sbattery?
Old Jul 5, 2008 | 7:09 PM
TMW597's Avatar
Default RE: Tow/Remote Battery
Yes. I had a 30 foot 2006 Toyhauler with two full size batteries that the truck would charge while plugged in.
Old Jul 5, 2008 | 8:03 PM
mary900's Avatar
TMW597 - thanks for the hope. However, a test light shows thatI do not have 12-volts at the plug. Tail lights andturn signalsDO show up okay with the test light.
Do you know what fuse number would complete the circuit?
Old Jul 6, 2008 | 12:18 PM
mary900's Avatar
The attachment shows the steps that resolved my problem.
[IMG]local://upfiles/14159/13EAD5DCB5C740B5A49202D8FC5AC84D.jpg[/IMG]
Old Jul 10, 2008 | 11:44 AM
So Mary, is this working to keep your trailer battery charged? If it is then I wonder if you could connect a AUX battery up to this same connection and have addtional power to the Tahoe?!?
Old Jul 10, 2008 | 8:40 PM
e's Avatar
e
technically you could in2pro. However it would not be the best way of doing so. If for any reason the tahoe's 1st battery would say go dead, then the full load of the vehicle would have too come from the 2nd battery. By going thru the smaller gauge wiring (the aux circuit) I would tend to believe that some over heating of the wiringcould occur, such as sending the higher current to the starter.
The best way to add that 2nd battery would be to run at minimum a 4gauge wire from battery to battery, and to do any isolating if you wanted to.
Old Jul 11, 2008 | 7:26 AM
mary900's Avatar
in2pro - sent you email.
uncleroyhobbs
Apr 5, 2012 1:59 PM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Sirius018
Jul 17, 2010 10:10 AM
rwrows
Apr 6, 2008 12:04 PM
