Towing with 2018 Suburban
Old Aug 31, 2020 | 9:33 PM
Jason PM's Avatar
Default Towing with 2018 Suburban
Hi - anyone have experience pulling a 7000 lb Airstream (25FB Globetrotter) with a 2018 Suburban WITHOUT the max trailering package? Truck is rated at 6000 lb max without the max trailering package. I believe the only difference between the “regular” tow package and the max is 3.08 gears vs 3.42 gears. I believe the frame, axles, engine (5.3L), hitch are all identical. Thank you.
Old Sep 1, 2020 | 3:30 PM
intheburbs's Avatar
It's not just the gear ratio, it's the coolers. The max trailering package adds, and I'm not sure exactly which ones, engine oil, power steering, and/or transmission coolers. So yes, your Suburban is going to have to work harder to pull the trailer with the 3.08 gears, and it's going to get even hotter because it doesn't have the additional cooling. If I were you I'd proceed with caution.
Old Sep 1, 2020 | 4:28 PM
Rednucleus's Avatar
And would be concerned with voiding any existing warranty if something breaks
Old Sep 1, 2020 | 9:14 PM
Jason PM's Avatar
My 2018 premier actually has both the external oil cooler and the external trans fluid cooler and temperature gauge on the driver info center. So I do believe the only difference is the gears.
Old Sep 2, 2020 | 2:48 PM
intheburbs's Avatar
While there's no mention of additional coolers, this is from the Chevy website...
Max Trailering Package
(Includes (GU6) 3.42 rear axle ratio, (JL1) Trailer brake controller and (Z85) Suspension Package. 4WD models also include (NQH) 2-speed active Transfer case. NHT is not available with (Z71) Off-Road Package or (WJP) Z71 Midnight Edition.) Max Trailering Package 3.42 rear axle ratio Trailer brake controller 4WD models include 2-speed active transfer case LS and LT models include Z85 Premium Smooth Ride Suspension Package with air leveler Included on LS models equipped with All-Season Package
Old Sep 2, 2020 | 10:02 PM
Jason PM's Avatar
Right I think no mention of coolers in the max package since they are already included as standard on 2018 premier. Trailer brake controller is something I would need to add. Two speed transfer case adds 4 low but I shouldn’t need that while towing in normal circumstances I would think. My suspension is Z95 vs Z85 included with max package. Z95 is magnetic ride control with leveling shocks in rear.
butlerc05
Traverse
Dec 18, 2018 10:52 AM
One1014
May 17, 2018 7:45 AM
Adam King
Jan 23, 2017 12:20 PM
OpenTrackRacer
Mar 2, 2007 4:31 AM
