TPMS not fitting after-market wheels
#11
RE: TPMS not fitting after-market wheels
That's actually a good idea addkev, I never thought of that approach.We have extra wheels all over the place from other pet projects so we won'thave to mess up the spare. Thanks!!
#12
ORIGINAL: mary900
Patrykkoul - thanks for the info regarding the DIC.
AZSCTACO - mounting strap is a new one for me. Is it a metal band that resides around the entire inside of the wheel? Do these mounting straps work with OEM sensorsor do they come with their ownsensors?
charlie pachanga - rims are too thick and the valve stem hole is only 7/16".
#13
I have tire pressure sensors that will work on all GM lan bus vehicles. 07 up tahoe, suburban, silverado, monte carlo etc. They are metal valve stem and chrome caps. Any one interested email me a I will give you pricing on a set of 4.
#14
Ruined several TPMS trying to adjust to new Budniks. Finally took Addkev's approach and put all four of the TPMS in a different rim. Manually re-learned the sensors and do not have the yellow DIC light. These wheels will come off during the winter so no big loss of sleep of not actually having TPMS during the summer.
#16
They are billets but drilling a bigger hole would not solve the issue. The rim is too thick for securing the valve stem. The ridge on the valve stem will be inside the rim as opposed to sitting outside of the rim surface where it is supposed to be.
#17
ok i forgt when i had a set of bonspeed wheels, they are also bilet ,the hole for the valve stem was also in the inside part of the rim.
#18
Here is answer to mount TPMS censor mount on AFTERmarket wheels.
Don't strap metal clamp inside of rim and don't make other hole to hold TPMS.
It won't be correctly read. But this will perfectly work.
Made by Iforged bracket and sold at www.themodcity.com $75.00 with shipped.
I have same one sale on ebay. Check this out.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250291629139
fireant510
December 15th, 2007 7:39 AM
