Trans temps
Old Jul 9, 2015 | 10:49 AM
Scotiapilot's Avatar
Default Trans temps
What temps are you all seeing?
I live in AZ and it gets HOT. I have seen 210 degrees on the trans temp, no towing.
Is that normal?
Old Jul 9, 2015 | 11:35 AM
intheburbs's Avatar
Yes, it's normal. Typical operating temp is 100° over ambient. 180-200° is common.
I believe you get the warning at 265°.
I've had mine as high as 235°.
Dexron 6 doesn't start to break down until the high 200s.
Old Jul 10, 2015 | 8:59 AM
SWHouston's Avatar
Most Fluid Manufacturers will list 200° as their recommended maximum. However, I think that's a conservative number, and many exceed that some. Given that the Fluid moves through the Capsule in the bottom of the radiator (which is good for warming it up quickly) you should see a minimum of 185° regularly.
Often times, with those who run in very hot ambient temperatures, will add an axillary fan to an existing cooler, or, that with a Diverter Valve, which initially directs the tranny Fluid completely away from the radiator capsule, and unloads that duty from the Radiator.
Old Jul 10, 2015 | 9:21 PM
retsub's Avatar
Do you have a towing package with the better trans cooler and fan or standard set up ? *BW*
Old Jul 13, 2015 | 12:01 PM
RPO
z82
The road temp here in AZ will easily reach 120+
99tahoeinwv
Feb 1, 2013 2:56 PM
JohnDeere
Aug 15, 2012 7:44 AM
ousig2408
Jun 14, 2011 8:34 PM
dennisp
Mar 16, 2011 8:20 AM
Yellow Yota
Dec 16, 2010 11:13 AM
