Transfer case destruction: *GRAPHIC**
Old Oct 24, 2019 | 3:24 PM
3/4tonSuburban's Avatar
Default Transfer case destruction: *GRAPHIC**
Removed from suburban @falconbrother
Random bearing from somewhere....
This the shot from underneath after the skid plate was removed. Still installed in the vehicle.
Old Oct 24, 2019 | 4:20 PM
falconbrother's Avatar
Cooool!!
Old Oct 24, 2019 | 4:28 PM
Even cooler was me limping this beast home after figuring out the transfer case completely failed. From the bridge to the southwest corner of MI.
I removed the front driveshaft and shift motor at the bridge, then used channel locks to put her in some gear to get her home. She would pop out a few times. (4) on the way back to home.
Old Oct 25, 2019 | 12:57 PM
What gear did you choose for that drive? Does your Burb have the 6.0 or the 8.1? I want a 6.0, 2500 burb. I'm using my 150, 5.3 to tow my camper, and it does OK. But, the 2500, 6.0 would do so much better.
Old Oct 25, 2019 | 7:54 PM
Since I removed the shift motor and selected a gear randomly, I really don’t know. I think it might have been 2WD, but since the front shaft was removed, it didn’t matter, as long as the vehicle moved forward. Lol.
I have the 6.0L and considering some upgrades. Either upgrading the 6.0L with turbo, or just dropping the 6.6L diesel in it. I’ve done a lot of research on that. There are a few conversions out there, and a lot more companies that offer it. Biggest issue is needing a donor truck for random parts.
I do know when the government orders the 3/4 ton they get the Duramax but civilians do not. They also made a 3500
version. Haven’t found but one of those online. @falconbrother
Old Oct 26, 2019 | 3:08 PM
intheburbs's Avatar
The government does not/did not ever get Duramax Suburbans. No such vehicle ever rolled off a GM assembly line. All 2500 and 3500 Suburbans have the 6.0 gas engine.
The last diesel GM put in a Suburban was the pre-2000 OBS trucks.
Back to your original post - what were you doing to cause such a catastrophic failure of the transfer case? How much were you abusing it?
Oldblue99
Jun 12, 2019 9:07 PM
Tin-man
May 13, 2019 1:35 AM
mountainmanjoe
Mar 19, 2019 10:08 AM
derrickwalter
Jun 13, 2016 9:14 AM
