Transfer case going bad???
Old Apr 5, 2010 | 1:56 PM
cdbrock24's Avatar
Default Transfer case going bad???
Is there any warning/noise/indication that a transfer case is on the verge of failing? I have a knocking noise everytime i start/stop, put into gear, make a 2/3 point turn, go over a bump etc. It sounds as if it's coming from underneath the driver seat. A mechainc told me it's the transfer case and it needs to be replaced. This is a 1900 fix. It's a 4wd 97 tahoe with 250K miles on it. So a transfer case problem would junk my car. Is this the noise such a problem would make? It seems to me it would have something to do with the suspension or drive shaft. Let me know. thanks.
Old Apr 5, 2010 | 2:55 PM
mudmaniac's Avatar
Ride of the Month
May 2009
It is possible that it's the transfer case. You could salvage one from a junkyard and do the swap yourself for a lot less money.
mshaw130
Jun 30, 2014 10:30 PM
Bobb7272
Jan 19, 2007 12:24 AM
jsshark1
Nov 17, 2006 2:01 PM
Crazebob
Sep 11, 2006 10:47 PM
vb547
May 21, 2006 4:00 PM
