Transfer Case Pin Hole Leak Question
Old Oct 28, 2010 | 9:41 AM
Bigdog777's Avatar
Question Transfer Case Pin Hole Leak Question
I have a 2003 Z71 Suburban with 150K miles on it....recently I noticed a pin hole leak (slow drip when hot) in my transfer case leaking the blue fluid....not sure if it's porosity or a crack but doesn't appear to be a crack that I can see. It's in a good spot to repair (from below) IF that can be done while still on the vehicle...I'm sure it would be very costly to R&R soooooooooo I'm looking for advice of IF and HOW would be the best way to deal with it. It appears to be a cast alluminum housing. I'm thinking...Drain/lower fluid...clean and either Epoxy, weld, tap and install screw etc...anyone have any experiance with this type of situation/repair? and thanks in advance.
Old Oct 28, 2010 | 10:25 AM
SabrToothSqrl's Avatar
Default blue?
I was under the impression transfer cases used automatic tranny fluid... which is generally red...
is that inaccurate?
nope: GM has a new Auto Trak II Transfer Case Fluid (GM Part No. 12378508), which has a bluish color to it
could be blue! go gm... way to mess w/the color scheme...
Old Oct 28, 2010 | 6:49 PM
Clean it very well w/ brake cleaner and seal it w/ 5 min JB Weld. If the leak is slow enuf, you shouldn't have to drain it.
Next way was as you suggested to drill, tap, and install a screw using a sealer.
Let us know how it works out.
Old Oct 28, 2010 | 8:15 PM
MDTAHOE's Avatar
Professional Mechanic
Use JB weld
BigMooseBob
May 21, 2012 7:54 PM
MDH71
Mar 28, 2012 4:22 PM
slepley
Dec 29, 2011 4:21 PM
Wick
Apr 24, 2010 4:46 PM
Crazebob
Sep 11, 2006 10:47 PM
