transfer case/transmission issues
Old Dec 2, 2013 | 10:04 PM
OgaraMastiffs's Avatar
Default transfer case/transmission issues
I have a 2004 Z71 Suburban with approximately 189k miles. Approximately 1.5 months ago I had the transfer case rebuilt at my local garage's recommendation. My SUV could only be driven in 4WD. Last night, while driving the same situation surfaced. Only able to drive the SUV in 4WD.
I took the vehicle back to the garage that rebuilt the transfer case. They are now saying the transmission needs to be replaced. Hate to be a girl, but would the vehicle be able to be driven if the transmission was "out"?
Old Dec 2, 2013 | 11:24 PM
SWHouston's Avatar
Welcome to the forum Ogara.
That sounds SO fishy it stinks ! Since they didn't repair the transmission, there's no warranty for that, and I'd get a second opinion from another Shop. Your problem sounds more electronic/control than it does mechanical.
Old Dec 3, 2013 | 10:47 AM
Thank you! I've been doing a lot of internet searches. Would the actuator have anything to do with this?
Old Dec 3, 2013 | 1:58 PM
SWHouston's Avatar
I wish I could be more specific, but situations like yours are very hard to diagnose by the written word :biggrin:
Go to a reputable Shop and let them listen and check it.
Old Dec 17, 2013 | 4:50 PM
Meridianman73's Avatar
You probably didn't need the t-case rebuild either.
This sounds like a symptom of a bad encoder motor. This part mounts to the side of the transfer case. It is about a $200 part ( reman works just fine). I think it is two hours labor.
A bad trans WILL NOT force you to drive in 4wd.
I usually would not recommend this, but take it to a GM dealer and get this fixed the right way, may cost more but they won't rebuild a major component when it is just a sensor or other small component.
tblt44
Avalanche
Feb 22, 2014 3:55 PM
guyute77
Sep 13, 2012 2:50 PM
Hotwell2000
Jun 2, 2012 4:43 AM
rowekmr
Aug 7, 2009 12:18 AM
