Transmission Leak
Old Mar 17, 2016 | 9:47 PM
emb505's Avatar
Default Transmission Leak
What are these 2 metal discs? Leak just started a few days ago.
2011 Suburban 59,000 miles.
Thanks
Attached Thumbnails Transmission Leak-leak1.jpg   Transmission Leak-leak2.jpg   Transmission Leak-leak3.jpg
Old Mar 18, 2016 | 6:51 AM
inspection covers. pry then out and you can see if a trail of fluid is coming from the torque convertor pump seal. if it is, the trans will have to be remved to replace this seal.
Old Mar 18, 2016 | 1:52 PM
cleveland63b's Avatar
x2
looks slightly dark in the pictures so you might want to verify if its engine oil or transmission fluid also.
Old Mar 18, 2016 | 2:32 PM
emb505's Avatar
I wiped it with a white paper towel and it was pink
Old Mar 18, 2016 | 3:55 PM
Scotiapilot's Avatar
I also thought the breather vent for the tranny is also in the bell housing? Is that right?
Old Mar 19, 2016 | 10:24 AM
emb505's Avatar
I was wondering the same about breather hose/vent as I cant find where else it would be
Old Mar 19, 2016 | 2:07 PM
the vent hose for the trans is on the top of the case....has a rubber hose attached to it that runs back to the transfer case.
I have never seen one leak fluid. it would run around the outside of the case and down if it did.
Old Mar 22, 2016 | 7:43 AM
{tpc}'s Avatar
Tech2, would you think that much fluid would pass out of the inspection covers? I wanted to say it looked to be coming down, but the second pic doesn't really show that. I'm just surprised that it kind flows up...knowing that the inspection covers are kinda at a low point there.
Old Mar 23, 2016 | 6:49 AM
fluid leaks move down and back.
remove the inspection covers. see if its dry in the bellhousing, flexplate and torque convertor area.
