Transmission Maintenance Advice
Old May 6, 2025 | 5:31 PM
gtrask's Avatar
Default Transmission Maintenance Advice
I recently bought a 2004 Chevrolet Suburban (~140K miles, 5.3L, 4WD). The transmission fluid looks light grey with some red tint, suggesting possible wear or contamination. The transmission is currently shifting smoothly with no noticeable issues.
I took it to Grease Monkey for a transmission service, but after reviewing Carfax (which shows no prior transmission maintenance), they advised against it. They said the fluid likely contains sludge or wear particles, and a flush could dislodge debris, potentially damaging sensitive components. They recommended leaving the transmission alone to avoid issues.
I’m leaning toward skipping the service based on their advice but want to hear from the forum. Has anyone dealt with a high-mileage Suburban transmission in similar condition? Did you service it (e.g., flush or partial fluid change) or leave it alone? Any issues either way? Are there safer alternatives, like a fluid inspection or partial drain-and-fill? Thanks for your input!
Old May 6, 2025 | 6:40 PM
elkhornsun's Avatar
Download the user manual for your vehicle and refer to it for frequency and type of ATF to use. Best to use a GM ATF that will not cause problems with the internal seals in the transmission. With every standard duty vehicle I have owned the factory recommendation was to only change the ATF when the transmission was being repaired.
You found an honest shop person and I would stick with him and his advice.
Old May 6, 2025 | 8:30 PM
gtrask's Avatar
Thank you! I appreciate this shop’s advice even though they could have gotten me to pay for service.
Old May 6, 2025 | 9:16 PM
jfmorris's Avatar
What I would consider doing is dropping the pan, changing the filter, and replacing the 5 quarts or so of ATF you will lose. This freshens things, gives you a clean filter, and does not dislodge stuff. It's the flush method used by the oil change places that causes old transmissions to fail. They hook up to the transmission lines that go to the cooler, and flush through the system under pressure, which dislodges crap that ultimately causes the failure. I changed fluid in a GM truck with over 100k on it before and had no issues, but I did not do a flush.
Old May 6, 2025 | 10:17 PM
Rednucleus's Avatar
+1 for filter & fluid change and might do yearly after that. I did a flush on our 93 Sub and needed a new transmission after less than 5000 miles (about 200k on the trans)
jfmorris
1988 - 1998 (GMT400)
May 23, 2024 3:30 PM
kevvy2k
Feb 20, 2018 5:31 PM
kevvy2k
Feb 20, 2018 5:25 PM
Chevy_Girl_Lol
Mar 10, 2016 11:58 PM
Joe In NY
Mar 28, 2013 4:48 PM
