Transmission temperature
Old Jul 10, 2007 | 12:32 PM
  #11
ZX1100F1's Avatar
Default RE: Transmission temperature
All Tahoe's are equipped with the integrated radiator core/transmission cooler but only the 4.10 gear ratio come with the auxiliary transmission cooler.
Old Jul 10, 2007 | 6:29 PM
  #12
BigAlCaribe's Avatar
I tow a 24ft boat for about 5 miles in 90+summer heatand the most I've seen is 194, hope this helps.
-Al
Old Jul 10, 2007 | 8:33 PM
  #13
genestoy's Avatar
I have the "optional" factory trans cooler with 3:73 gears and just drove from Phoenix north thru Nevada and Idaho in some pretty warm temps (115+) towing a 3500 lb trailer and a few pretty long grades on the way and the highest the temp ever got was 213 degrees. Normally it ran under 190 degrees all the time.
Old Jul 10, 2007 | 10:26 PM
  #14
H07's Avatar
H07
Made a trip today to Virginia Beach area my tranny temps were 208-210 running 70 MPH on semi flat roads not towing a trailer with one passenger....is this thing running a little warm?
Old Jul 10, 2007 | 10:56 PM
  #15
15 Year Member
ZX: Could one install the factory aux. cooler easily or would it involve cutting some hard lines? Also does the aux. cooler employ some kind of thermostat to prevent slushing the tranny fluid in extreme cold climates?
Old Jul 11, 2007 | 2:21 PM
  #16
ZX1100F1's Avatar
The aux cooler is pretty easy to install and does not involve cutting oil lines.
The cooler does not employ a thermo bypass valve, it is recommended that it be completely bypassed or removed in extremely cold weather.
The new Dexron fuids offer very good performance in cold weather as well.
Old Jul 11, 2007 | 2:30 PM
  #17
ZX1100F1's Avatar
ORIGINAL: genestoy
No such "option" offered with either a 2WD or any 3.73 equipped 2007 Tahoe.
The vehicle must be a 4X4 with 4.10 gear ratio to come from the factory with the optional KNP Aux Transmission Cooler.
Did you have this unit installed?
Old Jul 11, 2007 | 4:53 PM
  #18
RonH's Avatar
ORIGINAL: ZX1100F1
What is considered "extremely cold"?
Old Jul 11, 2007 | 5:22 PM
  #19
ZX1100F1's Avatar
Generally speaking if you operate in the lower 48 then you are not affected.
Extreme cold is typically in reference to the Arctic region were synthetic arctic ATF fluids are recommended.
Old Jul 11, 2007 | 11:54 PM
  #20
copout221's Avatar
ORIGINAL: Stingray
I would of thunk these things were already hooked up to a trans-cooler.
YEP.... I agree !!!
