Transmission Transfer case adapter plate broke
Old Nov 14, 2015 | 7:03 AM
nic25276's Avatar
Default Transmission Transfer case adapter plate broke
so other day i was getting on the interstate when a new u-joint i put in broke and drive shaft went flying around which in turn snapped the trans/transfer case adapter mount in half yes which sucks major A$$.
My question is what is the right part number for this piece?
I have a 2003 chevy suburban 1500 and it should have the 4L60E/65E transmission and i know it has the NP8 transfer case from what i can tell it has 6 bolts on both sides but not sure since it is sitting in driveway broke down till i can get it up in the air and take a better look at it. cause the reason i ask is that i have been looking at parts online/ebay and im seeing different part numbers etc. for this piece
Old Nov 14, 2015 | 8:30 PM
2000z71's Avatar
The only one I can find is 15724744
Old Nov 15, 2015 | 6:13 PM
nic25276's Avatar
Default transfer case adapter
yes that is the only prt number i could find as well. and i found that piece today and in process of putting her back together
Old Nov 16, 2015 | 9:49 AM
nic25276's Avatar
Default transmission extension housing
In this adapter piece is there 2 different lengths of it and if so how much does it effect how the drive shafts hook up?
Old Nov 16, 2015 | 11:19 AM
2000z71's Avatar
I don't know but it could make the driveline bind up or not hook up. If the part number is the same it should work just fine.
