Turn Signal/Headlight Confusion
During the day both turn signals work perfectly. When I turn on my headlights, the left turn signal (front and back) stay constantly illuminated and will not blink when I set the signal to the left. The right signal still works properly. Which component is failing/getting mixed up?
03 suburban
03 suburban
Followed the harness. The side marker wiring joins with turn signal lighting. The turn marker wire about 4 inches back from the bulb was crushed between a piece of plastic and the chassis. Once I prayed it free, put everything back together, problem solved.
