Turn Signal/Headlight Confusion
Old May 23, 2023 | 11:32 AM
danielhak's Avatar
Default Turn Signal/Headlight Confusion
During the day both turn signals work perfectly. When I turn on my headlights, the left turn signal (front and back) stay constantly illuminated and will not blink when I set the signal to the left. The right signal still works properly. Which component is failing/getting mixed up?
03 suburban
Old May 23, 2023 | 1:12 PM
Body Control Module
Old May 23, 2023 | 2:06 PM
repairman54's Avatar
Make sure the left headlight ground is clean and good. Signal light may share the same ground as the headlight causing weird feedback. Do this before going the BCM route.
Old May 23, 2023 | 4:05 PM
interestingly, the left park/turn/marker lamp shares a ground with the RIGHT headlamp.
Old Jul 25, 2023 | 9:46 PM
danielhak's Avatar
Does this mean I should check the right headlight socket for corrosion, how can I check the headlight ground?
Old Jul 25, 2023 | 11:57 PM
Yes. follow the harness. See where it's grounded to the body/chassis
Old Aug 14, 2023 | 11:07 PM
danielhak's Avatar
Default Problem found
Followed the harness. The side marker wiring joins with turn signal lighting. The turn marker wire about 4 inches back from the bulb was crushed between a piece of plastic and the chassis. Once I prayed it free, put everything back together, problem solved.
ODECiF
Oct 25, 2024 4:52 PM
James Picone
Aug 3, 2022 11:36 AM
Michael Barnes Jr
Aug 18, 2021 12:53 PM
Steve A W
Apr 5, 2017 9:48 PM
derrik38
Jun 4, 2007 10:02 PM
