Turn Signals dont work but Brake lights and Hazards do?!
Old Apr 16, 2026 | 3:17 PM
MiaElChivo's Avatar
Default Turn Signals dont work but Brake lights and Hazards do?!
I've just purchased a 95 suburban 1500 and have been having one heck of a time with the blinker lights.
I've changed the flasher relay, The brake switch, checked fuses, and replaced the multifunction switch. The situation improved from having the turn signals stay solid to not working at all after replacing everything.
Did I bump something im not seeing or is there another fuse/relay I haven't found?
I did find the relay thats up under the radio and changed that too. What is going on?
This is the under hood fuse panel
This is the fuse panel just inside the driver side dash. Behind the door.
This is the under dash relay box. Bottom right is the flasher relay and has been replaced.
This is the brake light switch.
This is the connections for the multifunction switch
This is the turn signal flasher relay
This is the point where the multifuntion switche's smaller of the three wires plug into. This part itself has not been touched.
Parks911
Jul 13, 2025 8:07 PM
L84sky
Nov 15, 2020 9:54 AM
SkylarMartin
1988 - 1998 (GMT400)
Sep 29, 2020 12:16 PM
antonovich
Oct 6, 2010 8:26 PM
bsr2002
May 22, 2010 3:59 PM
