A turned off AC/engine hot light came on.2011 tahoe.
Old Sep 5, 2019 | 4:40 PM
REGINA MILLER's Avatar
Default A turned off AC/engine hot light came on.2011 tahoe.
What should my 1st steps be with no experience to fix a truck 2011 model tahoe.
Old Sep 5, 2019 | 8:22 PM
oilcanhenry's Avatar
You'll need to see if you have coolant running through the lines, The A/C will normally shut down if the engine is too hot, If that is the case
and its checked with a thermometer, then something else is amiss.
Old Sep 6, 2019 | 10:10 AM
Cusser's Avatar
Look for low coolant or a coolant leak, talking about anti-freeze/coolant, not AC refrigerant here. Need to address engine hot issues.
If low on coolant, add and then run engine and check for leaks; common areas can be the hoses, the plastic radiator end caps, the heater connections (especially at the plastic connectors at the firewall), and the water pump.
Consider having it towed to a shop, they can use a cooling system pressure check device to find leaks.
Old Sep 7, 2019 | 9:47 AM
Sabino56's Avatar
Are you saying you turned off the A/C and the hot engine light came on?
or
the A/C turned off and hot engine light came on around same time?
Old Sep 10, 2019 | 7:52 AM
This could also be due to a bad temp sensor, or sensor wiring if no leaks are present.
Old Jun 1, 2021 | 12:43 AM
Mjgarcia944's Avatar
Default Ac engine hot light
I had this same issue ended up replacing the temperature sensor and it fixed the issue
Old Jun 1, 2021 | 8:42 AM
Cusser's Avatar
Make sure the electric fans in the engine compartment are BOTH operating.
Shalooby
Jul 7, 2021 11:21 AM
S_A_M_I_N
May 31, 2012 9:43 PM
silverado432
May 2, 2012 9:15 PM
CHUCK70
Jun 19, 2011 6:48 AM
