upper intake manifold is blocked by rear shroud. Help please.
Old Jan 10, 2013 | 11:40 AM
warehousefinder's Avatar
Default upper intake manifold is blocked by rear shroud. Help please.
Does anyone know how to remove the shroud on the back of the intake manifold? There is not adequate clearance to remove the manifold with this shroud still attached. I believe there is a nut on the back of the shroud, but it is proving to be very difficult to access.
Any tips/instructions are appreciated.
2007 tahoe, 5.3l flex, Z-71 4wd
Old Jan 10, 2013 | 12:47 PM
Nevermind...managed to get a 10mm socket on the nut and finally got it off and the manifold came off relatively easy after that. What a PITA.
Old Jan 10, 2013 | 8:37 PM
Welcome to the forum...
What were you working on that needed the removal?
Old Jan 11, 2013 | 8:35 AM
Thanks. Oil pressure sensor. I am replacing the knock sensor too while I have the manifold off. Anything more to replace or clean while the manifold is off? My Tahoe has 160k miles.
tcr1016
Feb 8, 2014 8:07 PM
stevetro1
Jan 27, 2014 6:04 PM
bakkenman
Feb 12, 2012 7:21 PM
fixitmanmc
Aug 11, 2011 3:04 PM
gulfcoastjoe
May 4, 2008 12:38 PM
