Vibration when decelerating
Old Jan 30, 2008 | 4:54 PM
mikesmith's Avatar
Default Vibration when decelerating
I have noticed that I am getting a vibration if my tahoe is above 45 when I am decelerating, I cannot figure out the problem. Any help is greatly appreciated,
Thanks
Old Jan 30, 2008 | 5:44 PM
Slammed's Avatar
Default RE: Vibration when decelerating
could be many many things
1.hub bearings
2.rotors
3.idler arm
4.lower ball joints
5.half shaft (front)
I say take it to a mechanic and have them check it out
Old Jan 30, 2008 | 5:53 PM
ZX1100F1's Avatar
Vibration when "decelerating" with foot ON or OFF brakes?
What year and miles on vehicle and also what size tires?
Old Jan 30, 2008 | 7:22 PM
mikesmith's Avatar
Foot is off the brakes, it is a 2001, with 76,000 miles. With standard size tires.
Old Jan 31, 2008 | 10:42 AM
ZX1100F1's Avatar
You're not driving in 4X4 I assume?
Does the vibration shake the truck (can all occupants feel it), or is it felt primarily thru the steering wheel?
The frist thing that I would do (starting cheap) is have the tires inspected and rebalanced, if that doesn't cure the problem then have the aligment checked and adjusted as well, most often these types of concerns are tire related.
If none of these things solve the problem you may want to start looking into the drive system checking u-joints, drive shafts and so on.
Old Feb 5, 2008 | 10:13 PM
SabrToothSqrl's Avatar
mine did this when the u-joints on the rear shaft wore out... $10 at AA...
Old Aug 6, 2008 | 10:03 AM
jman01tahoe's Avatar
ok just read other tips very helpful or motivating? !! lol no vib. thru steering wheel. others can feel it ...seeems more pronounced while making gradual turns l. or r.
GunnyV
Jun 2, 2014 9:03 PM
tcr1016
Jun 1, 2014 10:00 PM
greatwhite99
Aug 27, 2011 4:00 PM
mastermags
Dec 11, 2010 1:26 PM
dmames08
Feb 24, 2006 11:53 PM
