Want to add two 12 inch subs to 03 Tahoe w/Bose
Old Sep 21, 2006 | 3:43 AM
zoey's Avatar
Default Want to add two 12 inch subs to 03 Tahoe w/Bose
Anyone know what is required? I wanted to know what parts I need.
Old Sep 21, 2006 | 2:57 PM
negra07's Avatar
Default RE: Want to add two 12 inch subs to 03 Tahoe w/Bose
do you just want to add a sub amp and the two subs, than all you need is a loc converter which then you tap into the sub speaker leads under thye ceneter console.then run youre power cable from the battery and get the remote from an ignition source wire under the dash asn yo are ready. no toi deatiled but you get th e idea. later
Old Sep 21, 2006 | 6:57 PM
zoey's Avatar
Yeah....I want to add a sub amp and two 12s.................so just run a line for power from the battery. Speaker lead from the center console?
Old Sep 22, 2006 | 3:39 AM
TRock's Avatar
Yeah under the center console you will find the rear speaker leads, you can also tap into these behind the deck but its more work. Then for about 15 bucks you need to get an LOC converter, also known as a high low converter. what this does is takes the signal from the speaker wire and converts it to a signal that can be sent through rca cables to your amp. So once you have done that, you just need to run a power wire (4 guage rules) from the battery, preferably with a fuse on it to the rear of the vehicle. Personaly I used a rear seat bolt as the location to tap in for a ground. If you want or need more info just reply with your msn and I can even draw you a diagram. Currently I'm running a Rockford setup in mine and I love it!
Old Sep 22, 2006 | 3:05 PM
zoey's Avatar
u can find my msn by looking via email. goconnell@mgocpa.com
Old Sep 22, 2006 | 3:07 PM
zoey's Avatar
Galen O'Connell (3538)
07LT3BEE
Jul 6, 2022 10:42 PM
marc32123
Cobalt
Sep 20, 2014 10:01 PM
Ryno
Aug 16, 2012 6:26 AM
soundobsessed
Avalanche
Aug 26, 2007 10:34 PM
Tahoeguy2
Apr 22, 2007 5:08 PM
