Water getting "inside" ?
Old January 5th, 2023 | 3:38 PM
  #11
Wavelength's Avatar
Default Water under door trim
Originally Posted by 04Z71SuburbanDude
update: I have found my issue possibly. While using a shop vac to try and get as much water as possible out of the carpet, I said why not I’ll take the step trim off and when I did that, there was tons of water on the carpet under it and the sound proofing was soaked. So it has something to do with the door seal.
I found water under door trim soaking front carpet coming from the roof rack, through left side support column, and down past the fuse panel. I isolated it by carefully pouring water into the fore/aft roof strut and letting it accumulate at the forward end. Good Luck and Cheers. Wavelength.
Old February 25th, 2023 | 10:30 AM
  #12
BerserkerJack's Avatar
What a head scratcher, right? Well........I found it. After the "dealer" said, "it ain't clogged drains, its the windshield seal". I had a fella all set to swap it out, then he said..."I'm just gonna check one thing first BEFORE I swap a windshield". He blasted with the water hose until I saw water coming in. Then he found this after visually inspecting where the water was coming from. A freakin HOLE right above the front blower motor. You can even see the hanging duct tape where someone attempted a patch.
Rednucleus (February 25th, 2023)
Old March 3rd, 2023 | 1:23 AM
  #13
KChevy75's Avatar
Water shouldn't be collecting there anyway. You have a leak but It's not going to be the windshield. Two places they leak. The inside door seal that slips around the pinch went around the door opening tends to leak. Quick and easy fix it to pull it off and squeeze the u-channel together so it's tight again and reinstall. There's a u-shaped piece of metal inside and it fatigues over time and gets bent by people drabbing it while getting in and out.
The second place is under the cowl cover on the passenger side. Remove the wipers and remove the cowl cover. There will be a body color rectangular cover that's supposed to be permanently glued over an opening above the hvac box. The seal breaks and the cover separated from the cowl. I carefully removed mine then using a generous amount of sealant (RTV works well) I apply the sealant around the edge then install the cover then tape it down while the sealant cures. Once cured, remove the tape, reinstall the cowl cover and reinstall the wipers.
Splathapy
January 5th, 2023 12:26 PM
Mark Hubley
November 13th, 2020 6:52 PM
yamiyalo
July 19th, 2011 5:46 AM
Grand.
June 21st, 2011 6:16 PM
thegibl
April 7th, 2011 1:18 PM
