what size tire for 22 in wheel?
Old Oct 14, 2007 | 4:44 AM
jinzhenheng's Avatar
Default what size tire for 22 in wheel?
hi
just had question about tire. currently i have 22 wheel with 305/40/22 tire i m planning to powder coat my rim and just thinking of getting new tires. well went to couple of places to look at tires some places recommend 285/45/22 and 305/45/22. my tahoe is stock height. whats the big difference? will the tire affect my towing ability? i just want a tire that has less gap and still have same towing ability as stock so which should i go with? please help me decide~
Old Oct 15, 2007 | 7:06 PM
P_RsTahoe's Avatar
Default RE: what size tire for 22 in wheel?
If you have the correct off-set for the 07's I recommend 285/45/22. Thats what Im running and they run smoother than the 305's did.
Old Oct 17, 2007 | 12:11 AM
paradisepatiosAZ's Avatar
J -
I'm running the Nitto 285/50R22's with a Rancho Quick Lift on the front and thankfuly so. It is tight - tight. I also had to trim about an inch off of the rear inner fender where it bulges for the shock bolt. It rubbed bad when I loaded the boat trailer. Just an inch cured it. Up front it nearly rubs the front outer edge on the inner fender when cranked inboard & the rear outer edge has rubbed about 1/3 of the way in on the back of the inner fender when cranked and backing over a bump. Just gotta be cautious how we drive in some instances now...
Hope this helps your decision.
Old Oct 17, 2007 | 3:04 AM
thanks for the input well found out that my momo wheel offset is 20 so can i go with 285/45/22 ?
Old Nov 19, 2007 | 8:00 PM
Golferal's Avatar
I have the 305's (Falken Ziexon mine and I'm not entirely pleased with the ride quality. I will definitely go to the 285s when I have to buy rubber next time. I also get a little rubbing in the rear under load.
SC_CountryBoy3
Dec 7, 2013 12:02 PM
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
slammerslugs
11
Aug 12, 2008 1:48 AM
WOODDOGG
Jan 29, 2007 11:17 PM
technoswede
Jan 3, 2007 9:15 PM
