What and Where?
Old Mar 29, 2010 | 7:34 PM
PastorK's Avatar
Default What and Where?
I need one of these. What is the technical name of it and where do i get it?
Off the High side on the A/C system.
Attached Thumbnails What and Where?-play-022.jpg   What and Where?-play-023.jpg   What and Where?-play-024.jpg   What and Where?-play-025.jpg
Old Mar 29, 2010 | 7:39 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I think they call it a quick connect charging port, I think you need to get it at the dealer.
Old Mar 29, 2010 | 7:50 PM
PastorK's Avatar
maybe not the dealer? Is this the same?
http://www.autozone.com/autozone/cat...ndName=Santech
Old Mar 30, 2010 | 5:49 PM
PastorK's Avatar
Just for the record, Autozone can order them, and O'Reily has them in stock. I paid $4 for it. Now time to recharge the system again. Both dealerships that I talked to said that they don't sell just the valve, you can only buy the whole assembly through them. (for $125)
Old Mar 30, 2010 | 6:05 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Glad you got it figured out, be sure to charge the system thru the low side.
Old Mar 30, 2010 | 7:14 PM
PastorK's Avatar
Not me my friend, I'm letting the mechanic do the freon.
Old Mar 30, 2010 | 8:48 PM
If you didn't replace the dryer (probably should if the system was open to the atmosphere), then be sure he pulls a hard vacuum for about an hour to remove any moisture and then shut the vacuum pump off and make sure the system holds the vacuum so you know there's no leaks. If he's a certified A/C tech, then he knows all of this.
