Wheel bearing/ABS
Old Jan 18, 2013 | 12:47 AM
cbe295's Avatar
Exclamation Wheel bearing/ABS
I have a 2001 Suburban 1500 4 wheel drive. The abs and brake light have been on since I bought it. I replaced a bad wheel bearing today and thought it would shut the lights off but it hasn't. Can anybody help.
Thanks
Old Jan 19, 2013 | 5:15 PM
go-part's Avatar
Former Sponsor
It can also be the VSS(vehicle speed sensor) also known as the abs sensor causing the abs light to come on. Check and clean them first.
Old Jan 19, 2013 | 7:18 PM
Doesn't the new bearing come with a new WSS (harness)?
Have the code read to determine which Wheel location the problem is occuring from.
Old Jan 19, 2013 | 10:10 PM
cbe295's Avatar
The wheel bearing came with a new abs sensor. I found out the problem with the ABS lights. Someone took out the fuse. So I replaced the fuse and the lights went out. But I still don't have 4 wheel drive. I have replaced the actuator. I have no other ideas. This is my first push button 4 wheel drive.
Old Jan 19, 2013 | 10:11 PM
cbe295's Avatar
Also, thank you guys for helping.
cjfelsinger
May 27, 2014 3:46 PM
schuey59
Apr 10, 2012 1:38 AM
subirs05
Aug 7, 2008 12:44 AM
reds_21
Sep 10, 2007 6:15 PM
settlesean
Apr 9, 2007 6:59 PM
