WHEEL AND TIRE ADVICE!
Old Jan 13, 2008 | 1:04 AM
PG44509's Avatar
Default WHEEL AND TIRE ADVICE!
I just picked up my first 'hoe...2003 LT.. I am looking at getting a set of raceline rampage 6 wheels, black with the chrome hub to match the black truck..don't want to spend a ton....Any thoughts on size? 16, 18 or 20 with a n agressive tire..also could I fit at 33 inch tire with out lifting it?
Old Jan 14, 2008 | 11:09 PM
engine2's Avatar
Default RE: WHEEL AND TIRE ADVICE!
check out tirerack.com
Old Jan 15, 2008 | 11:13 AM
GMz71's Avatar
you will probably have to crank your torsion bars to fit 33s....you might be able to get them in there without doing it...you probably want to stick with stock backspacing to fit the 33s in there.
tires to consider: BFG A/T TKO, Nitto Terragrapplers, Bridgestone Duelers Revo, Toyo Open Country A/T.....unless you want to go to mud terrains. If you want to also save some money, you probably want to stay under 20s because tires start to get expensive the larger you go.
x2 on tire rack...very helpful website, thats were I bought my tires/rims from...and you can view them on your truck
Eddie.805
Feb 8, 2015 6:38 AM
lph008
Mar 9, 2014 7:15 PM
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
lauraherota
Oct 19, 2011 9:04 AM
sw4bama
Dec 21, 2008 9:02 PM
