Where does this bracket go on my 5.7 vortec?
Old Dec 10, 2024 | 7:27 PM
grantbar's Avatar
Default Where does this bracket go on my 5.7 vortec?
I just replaced the intake manifold gaskets on my 1999 Suburban 5.7 Vortec engine. I ended up with this bracket, but I don't know where it goes. From the plastic clip, it looks like it holds a water hose. It is held down by one 10mm nut. But for the life of me, I cannot figure where it goes. I should have labeled it when I took it off. Any ideas? Thank you
Old Dec 10, 2024 | 8:30 PM
LarryE's Avatar
I just sold my 99 but I will check my 97 in the morning. It might be the same. It is too cold and dark outside right now.
Old Dec 11, 2024 | 8:56 AM
grantbar's Avatar
That would be awesome if you could do that. Thank you!
Old Dec 11, 2024 | 9:45 AM
LarryE's Avatar
On my 97 there is a very similar bracket bolted to the right rear of the intake manifold (or maybe the block, but I think the intake). It angles back to the firewall and supports a one inch wire bundle. That wire bundle would fit that plastic hold down clip on your bracket. It looks like you would have to remove the air intake to reinstall it. Look for a stud sticking up in that area.
Old Dec 11, 2024 | 10:01 AM
grantbar's Avatar
That was it! I was thinking water line, but you are right, is for the electrical bundle. Thank you so much! Love the Forum!
bashbro
Mar 30, 2020 8:59 AM
Brinker
Oct 6, 2011 12:46 AM
acer9876
Sep 3, 2011 10:50 PM
freedommbs
May 22, 2011 6:48 PM
cb1
Dec 10, 2009 6:35 PM
