Whirling noise coming from under truck. Need advice.
Old Mar 12, 2013 | 8:08 PM
  #11
bossman79's Avatar
Originally Posted by MDTAHOE
Put your ear to the fuel filler, does it sound like it is coming from inside the tank? I have seen many times on GM trucks where the fuel filter becomes very restricted thus causing the fuel pump to work to hard which makes it louder. Sometimes if caught soon enough filter replacement will quite down the pump. If not caught soon enough pump failure will eventually happen.
On a side note sugar will not dissolve in gas. All that needs to happen is removal from the tank. Because the pump has a "sock" on the bottom the sugar can never get into the pump or injectors.
Took the gas cap off and had a listen. Sounds like the noise is in indeed coming from the gas tank. I guess the next step will be to replace my filter and hope that alleviates the sound. Keep ya posted.
Sebastian Saldana
Jan 10, 2014 2:23 PM
Brandon2007Tahoe
Oct 27, 2010 7:47 AM
Chevy_gurl
Mar 2, 2010 1:01 PM
