Window Issues
Old Feb 5, 2021 | 12:50 PM
Charlie Freeman Oakley's Avatar
Default Window Issues
My window stops after a second. I have to push the button over and over so it can inch up as well as down. Is this a fuse issue or the switch?
Old Feb 5, 2021 | 8:03 PM
lube the guides with silicone spray and see if that helps
Old Feb 6, 2021 | 9:44 AM
Cusser's Avatar
Definitely NOT a fuse !!!! That's not how fuses operate !!!
I also agree with 100% silicone lubrication into the channels, worked on my 2004 Frontier window.
Old Feb 6, 2021 | 9:55 AM
kevinkpk's Avatar
There is a youtube video on how to clean switch. It could be the switch, I did mine last year as the rear window wouldn't always roll up, and had to press the lock button 3-4 times to get the doors to lock.
Old Feb 6, 2021 | 2:00 PM
I have seen window switches with thermal breakers. When they are overloaded for too, long a bimetallic strip opens up and breaks the circuit.
Old Feb 6, 2021 | 2:26 PM
Rednucleus's Avatar
If you "help" the window by pulling up or pushing down, does it keep going? If yes, probably not a switch problem.
justin69
Feb 28, 2015 2:54 PM
biged0412
Nov 24, 2014 9:49 PM
pose_master
May 2, 2010 1:23 AM
pcharles
K5 Blazer
Oct 18, 2009 9:03 PM
98greenventure
Apr 1, 2007 3:15 PM
