Wiper functions work but wont turn off
Old Jun 17, 2014 | 10:16 PM
watersfamily777's Avatar
Question Wiper functions work but wont turn off
Hey, new to the forum, pretty excited!
I have used it many times as a guest!
I have a question I can't find a thread for:
My wife's 04 Tahoe's wipers will not turn off BUT unlike most they DO maintain every control- each intermittent setting, low, med, high. On the 'Off' setting it operates as though it is on the lowest intermittent setting. To add a strange twist, when I put it on Med it continuously sprays washer fluid (while operating on medium speed).
My guess is multi funciton switch. I don't want to invest, do the swap and then find out it's the control module or something else. Those are my guesses. I've pulled the fuse until I figure something out.
I deeply appreciate any help you can offer!
Old Jun 18, 2014 | 8:04 AM
{tpc}'s Avatar
Did the 04's have rain sense? I don't think they did, but I honestly have no idea when it was introduced.
It all sounds like a multi function switch issue to me. I'm sure you have researched the cost of one, if not though I'd check with a local junkyard or ebay or something for a used one. Its possible to swap a bad one in, but if you did I doubt it would have exactly the same things wrong. If it acted the same way then it is something else...maybe a body controller or something?
Old Jun 18, 2014 | 9:39 AM
Thanks for your reply.
No rain sensors.
I may run to pick & pull. New Multi Funct switch is $102, New Pulse Module $70. Didn't want to replace a working piece . I may run to the junk yard later this week. As you said, if it doesn't work- it'd at least be different enough to help me define my problem.
Old Jun 19, 2014 | 3:25 PM
Welp, no junkyard in the area has the mulitfunction switch. Strange.
I really don't want to buy BOTH, anyone know if it's the multifunction switch (wiper controls) or the pulse module/wiper motor control module that I need to be looking at??
Old Jun 29, 2014 | 4:56 PM
Wasn't mf switch.
Going after wiper motor next. Anyone know for sure? Throwing parts at it is expensive.
ruley73
Sep 15, 2017 8:11 AM
JOUT22
Mar 8, 2013 3:13 PM
Mr. Vann
Nov 25, 2009 7:24 PM
nocodasmom
Oct 11, 2007 7:34 PM
