XBOX PSIII
Old Apr 18, 2007 | 8:47 PM
07summitwhite's Avatar
Default XBOX PSIII
Anyone know what size power supply I need to run it in my suburban?
Old Apr 18, 2007 | 9:01 PM
Default RE: XBOX PSIII
If you are referring to an inverter (DC to AC), I run my laptop with 150 watt unit.
Check the xbox and see what it's power consumption is. If it just gives you the current draw, multiply by 120 to get watts.
Example: If the current draw on the xbox is 500 milliamps (0.5 amps), you draw 60 watts.
Old Apr 18, 2007 | 9:04 PM
Yup, I guess that's what it is. I don't know how to check the system, is it on a label somewhere?
Old Apr 18, 2007 | 9:20 PM
It should be on the box that plugs into the wall outlet.
Old Apr 18, 2007 | 9:26 PM
The only thing on it is
100V-127V-2.1A
50/60HZ
Old Apr 18, 2007 | 9:53 PM
jlenkows's Avatar
That's 2.1 amps....
Old Apr 18, 2007 | 10:21 PM
So it's safe to say I need a 250 watt inverter [slaps sefe in head]?
Old Apr 19, 2007 | 12:02 AM
jlenkows's Avatar
or just a really long extension cord... ;-0
Old Apr 19, 2007 | 12:10 AM
ORIGINAL: 07summitwhite
I'd get a 300 watt one just to be on the safe side cuz 2.1 amps at 120 V is 252 watts.
Old Apr 19, 2007 | 1:52 PM
Thanks. I think I'll go with the 300 also.
07summitwhite
May 14, 2007 3:42 PM
