ZX what is your opinion on a Liquid Vac to change oil and tranny oil
Old Jan 9, 2008 | 10:10 PM
Big D's Avatar
Default ZX what is your opinion on a Liquid Vac to change oil and tranny oil
I have a liquid vac (suction pump used to vacuum oil) that I used to change the oil on a Chrysler Crossfire (hey what can i say it was an impulsive mid-life crisis toy). I also use it on my HD Road King. The question is can I use this pump to change the oil on my '07 Tahoe? It looks like it is a straight shot to the oil pan through the dipstick for both the oil and the tranny fluid as the dipstick does not have any heavy bends. ZX what do you think? I know the oil sludge issue, but the pump actually has very good suction and i believe it to be adequate. The oil vacuum, while not as quick as a drain, is a clean and easy way to change and transport used oil.
Old Jan 9, 2008 | 10:23 PM
ZX1100F1's Avatar
Default RE: ZX what is your opinion on a Liquid Vac to change oil and tranny oil
Should pose no problem or issues.
I would just recommend that you first check the oil level (6qt capacity) and after completing the vacuum process make sure that you got about 6qts of oil out.
Most boat recreational motors are done in this manner.
Old Jan 10, 2008 | 6:38 PM
Big D's Avatar
Thanks ZX
The crossfire held 8 qts of oil and it took about an hour to get it out, but once you set the suction you can watch tvand come out and repump the vacuum to pull the rest of the oil...change the KN oil filter and you are done... should not get too dirty and no oil spillage from the oil drain plug (as you know the thing drains with a lot of force and almost always overshoots the oil drain pan below....
Old Jan 10, 2008 | 6:53 PM
ZX1100F1's Avatar
Oh I know.
I figure that if I have to crawl under to change out the filter I may as well pop the plug while I'm under there, I normaly let the oil drain for 30 minutes or more while I drive to the parts store to buy the oil filter that I forgot to get earlier.
dh0765
Aug 26, 2014 7:01 PM
DeHartShadow
Mar 28, 2010 10:10 PM
SubliminalME
Sep 8, 2009 12:43 PM
MudHawg
K5 Blazer
Sep 28, 2006 3:45 PM
