04 suburban acts like run wire voltage flickers
Old Jul 2, 2011 | 4:25 PM
  #11
No problem...
Did it really get better or have you seen reprieves like this before?
Reason I ask is if it did get better you may be on the track of identifying the issue...I would also check the grounding to the chassis and body as I am not wholly convinced its not a grounding issue..
Aside from that the next thing that comes to mind is a possible BCM issue..
you could try to dismount and isolate it and see if that makes any difference...
Old Jul 3, 2011 | 12:41 PM
  #12
mattcotools's Avatar
I think it is better, the bumps have to be fast and strong now. Going to make some auxillary body ground cables this afternoon.
Old Jul 3, 2011 | 3:32 PM
  #13
Its not better, tried extra body grounds, extra power source to fuse block, Symptom reveiw: bumps- cuts power intermintant, door locks activate, average econ deal and engine oil life monitor resets, abs lights come on, will die sometimes dependant on the severity of the fit, will sometimes go into reduced power mode, will sometimes not restart without unhooking the battery and when that happens the gear indicator light is not present so i think it can't tell if it is in N or P to let it start. after unhooking and hookin the batt. up it starts. Maybe I'll start buying random electrical parts off ebay and trying them.
Old Jul 3, 2011 | 4:48 PM
  #14
Man its just not pretty at all is it...removing power is resetting the BCM...
might want to check any grounds that run to it...the BCM would be my would be my first shell in the chamber....
it might be worth a drive to the dealer for a sanity check....
Old Jul 4, 2011 | 11:36 AM
  #15
I just can't do that, it would crush my wrenchin soul. Havn't reference automotive electrical diagrams before, only caterpillars (they get crazy too some have 5 ecms!!) but will gm grounds be all blk, or blk w/stripe, just wondered if they have a common denominator. Will check those bcm wires, but when I unhooked the bcm before, the ave econ display did not reset... in a spaz out it does???
Old Jul 4, 2011 | 3:05 PM
  #16
Might check the ECM connector for any bent pins or corrosion.
Old Jul 4, 2011 | 10:30 PM
  #17
ecm pins were clean straight and beautiful, tugged & twisted on every last wire while unhooked, all looked sharp there.
Old Jul 5, 2011 | 9:33 PM
  #18
bcm checks out
Old Jul 12, 2011 | 8:38 PM
  #19
after a week and a half of running fine it did it again, this time I found a broken ground wire at the back of the right head. Mission accomplished.
Old Jul 13, 2011 | 9:35 AM
  #20
good job, fingers crossed that was the root...
is it something you could take a picture of the area it was in?
Jakester
14
Jun 15, 2023 11:38 AM
KrisDC2
Nov 2, 2011 8:42 PM
Huckabee2012
Jan 26, 2011 9:46 PM
espy59lc
Jan 16, 2009 10:06 PM
resivorfrogs
Astro
Aug 17, 2008 12:03 AM
